Working on a 75 1.8 with original fuel injection.
Engine runs okay at higher rpms, but runs very rough and rich at idle.
With engine running (stumbling at idle) if I take the oil breather cap off or remove the hose from the auxiliary air regulator the engine smooths out and idles up.
I have checked the temp senser and the auxiliary air regulator. Both are within ohm specs. And there are no vacuum leaks.
Any help would be greatly appreciated!
Jon
