7TPorsh
Oct 31 2016, 10:00 AM
I spent the weekend getting my new 914rubber dash top vinyl in. I'm using the early brickmold pattern instead of smooth. i didn't like the previous smooth; it was too shiny.
So vinyl is down and defroster vents are in. Now I'm trying to line up and get the dash on. It clips in the holes but.....
where do i access the bottom of the plastic bolts so I can tighten the dash down so there's no gap? It seems it was never "bolted".
altitude411
Oct 31 2016, 10:19 AM
76-914
IIRC, and I can't even remember what I ate for breakfast, you need to remove the radio, both vent registers, gage cluster.
Like your hat designs.
JoeD
Oct 31 2016, 10:30 AM
If I remember, you can reach up under the dash and get to a couple... maybe on the passenger side. I pulled the kneepad, gauges (but not entire cluster- you can pull the gauges forward and let them "hang" if you can reach your hand through), radio, glove box. Even so it was one HELL of a job...
Midway through I ended up driving over to Harbor Freight and picking up a set of stubby metric ratcheting wrenches that made a huge difference as some of the nuts would only turn 1/8 - 1/4 turn due to clearance.
Most difficult are the ones behind gauges. Trying to get the nuts on the plastic bolts and get them started using a couple millimeters of finger tip...the devil's own work. Had to walk away at least twice and come back to them.
But in the end it looks absolutely amazing, and I wore the bloody scrapes on my knuckles like medals!
malcolm2
Oct 31 2016, 10:51 AM
Hell I gave up when I could not even see the ones above the gauges.... I wish I had messed with it when I had all dash bits removed. Gonna just live with the ugly shrunken mat up there now. Kinda adds to the patina!
Larmo63
Oct 31 2016, 10:25 PM
The two plastic nuts that hold the (front?) back of the gauge pod can be started with needle nose pliers. Get them going that way, then carefully use a wrench. I didn't find it that hard, it just takes patience.
Frankvw
Oct 31 2016, 10:49 PM
Besides already given tips and tricks...
https://youtu.be/4265P_1eE_kor this
https://youtu.be/QZPoQd_V-6omaybe this will add some info
RARE 6
Nov 1 2016, 01:50 AM
Find a small agile German with long narrow fingers. This is the devil's work. As mentioned earlier, an assortment of short, stubby 1/4" ratchet wrenches, flexible connectors, short and long sockets and extensions will help. Finally gave up on a couple of the nuts in the middle of my re-install and called my wife down to the shop to get them started. Have a picture somewhere of her laying on her back in a mostly stripped interior staring upward under the dash while glaring at me. Another bit of family bonding over the -6.
JoeD
Nov 1 2016, 10:41 AM
QUOTE(RARE 6 @ Nov 1 2016, 03:50 AM)
7TPorsh
Nov 1 2016, 10:50 AM
I managed to get to the two on each side of the ashtray. But the two in the back for the "hood" don't look like the picture.
There is very little gap to even get the nut in there much less line it up or turn it. My dash is where the green line is....I can barely even see the bolts. I'll take pics tonight but here is the sample picture with comments.
....also I have an early dash so no left side vent. That bolt is totally hidden.
dlkawashima
Nov 1 2016, 11:40 AM
QUOTE(7TPorsh @ Nov 1 2016, 09:50 AM)
I used a 13mm cone wrench for the two nuts in the hood. For the nut on the far left side of the dash, try a "thumbwheel" or "finger" ratchet or a mini ratchet with a flex head.
