I am ready to install my new windshield on my 914. I am using 1/4 08610 3M buytl rope. I have the chrome trim replacement rubber seal from 914Rubber that hooks behind the outer glass edge. I have the 2 - 914Rubber setting blocks that lay at the bottom edge of the windshield pinch weld. Here are my questions.
1. It seems like the 2 914Rubber setting blocks are two skinny at 1/8 inch thick.
The setting block shickness at 1/8 in would not allow for enough space to stuff
and hook the 914Rubber chrome replacement trim between the bottom glass
edge and the lower pinch weld face where the OE trim clips holes are guued
shut? The setting blocks seem to me should be about 1/4 inch thick or about
double the OE trim clips thichness.
2. I can see problems with the 914Rubber chrome replacement seal not laying flat
at the 2 lower corners because of the severe glass bend. POOCHING?
3. Even if I was to go back to the OE chrome trim the rubber setting blocks at the
bottom don't seem fat enough for the lower edges of the window to sit properly.
Looks like the 914Rubber setting blocks are the same height as the trim blocks.
I would think the setting blocks should be higher than the chrome trim clips?
I am thinking the best way to get a quality job is to forget the rubber seal and go back to new OE chrome trim.
Any ideas from any who has been down this road.
Thanks
