QUOTE(Korijo914 @ Nov 2 2016, 02:08 PM)
Okay guys & gals, do you understand what I am trying to do? I want to either swap the guts from my 5 speed tail shifter to my 4 speed side shifter, or is it easier to change my tail shifter to a side shifter? I am trying to get a 5 speed side shifter!
What is the easiest way to do that?
Info needed! No hurry, tho!
David ( korijo 914 and keoneeli ) Cawdrey
David,
I've never heard of a 4 speed sideshifter, all of the 901 transaxles that were installed into 914's were 5 speed regardless of Tailshift or sideshift. The gears are all the same, the main difference is the shift selector rods in each transaxle and how they are actuated.
But to answer your question, you should be able to put the gear stack/intermediate plate from your tailshifter into your sideshift case, but you will have to use the shift selector rods from the sideshifter, do this all on the bench before you install into your sideshift case. Of course you will need to align all three shift selector forks with a jig prior to the install. The best way is make a jig from an old gearbox case. I'll try to find a picture of the one I use.
Do you have a copy of the factory manuals? Either paper copy or PDF? Follow the instructions for aligning the forks from the factory manual, very straight forward if you have the jig to hold your gear stacks.
Cheers,
Dominic
