It's an easy adjustment and I've done it many times but with the last few (even with a new TPS) it seems that when the car isfirst started & running cold, I can just touch the throttle & move it ever so slightly & that's when the car wants to quit running. If I go past that point it will pick up & run.
When I adjust the TPS by the Bird article, it says to move one more hash mark after the ohm meter jumps to zero. Sometimes the needle jumps when I'm between hash marks. So, do you move to the next hash mark making only a 1/2 a move or do you move past that closest mark to the next one making it a 1 1/2 hash mark movement?
Anyone ever experiment with their movements (on the TPS)
.......b
