Credit and Inspiration to this thread: http://www.914world.com/bbs2/index.php?sho...104513&st=0
This is my attempt to convert from Subaru AWD to 2WD tranny using their own internals.
So…! I pulled the engine out and I’m going for a Subaru tranny.
I pulled out the transmission cover and removed the differential.
I put the whole differential in a flat surface and make 2 tag welds to fix in position the whole differential.
I did a test fit on the transmission, to be sure that the gears did not moved during the tag welding. Did the necessary measurements to cut the differential. Then proceeded to cut the differential (had to pullout the bearing first).
