QUOTE(Sea Dragon 914 @ Nov 6 2016, 09:21 AM)
I had an exhaust leak on my LE so I thought I'd get into it today.
Took things apart and lo and behold one stud was missing. I took off the heat exchangers and checked the thread in the head and it looks good. Do I have to get a special stud or can I go to the hardware store and get the right size? If I have to get special ones, where can I order from?
Also, I seem to recall that I used Blue loctite. Is that correct or should I use Red?
Thanks,
SD
If your engine is a early 2.0 and the heads have not been tapped for oversized studs they'll be 8x 1.25 on both ends and 55mm long - 8 x 1.25-8 x 1.25 x 55mm.
Later 2.0 heads came from the factory with 9 x 1.25 on the cylinder head end and 8 x 1.25 on the other end 55mm long - 9 x 1.25-8 x 1.25 x 55mm. I think they started that in '74 but can't recall for certain
All 1.8's came with 9 x 1.25-8 x 1.25 x 55mm
All 1.7's came with 8 x 1.25-8 x 1.25 x 55mm
All of our new T4 heads - and any head we ship with new exhaust studs - the ex. studs are installed with Jet Lube 99.99% pure Mil Spec Copper Anti-seize with an operating temp of 1800*. The number one imperative is to protect the threads in these heads. This stuff does that very well. The Permatex version works just fine.
On my own car I slathered it all over the studs and in the oval counterbore the copper gasket slips in. It's sticky enough to hold the copper gaskets in place.
