simonjb
Nov 7 2016, 03:29 PM
Hi
My headlights will rise up, but they won't turn on when I pull the switch to the second position. All of the fuses are fine. Next thing to check?
Thanks
pbanders
Nov 7 2016, 03:38 PM
Get the wiring diagrams from Pelican Parts website and start voltage tracing the wiring. I'd start at the switch.
Frankvw
Nov 7 2016, 04:36 PM
Do you get 12v at the fitting? Check bulbs themselves (if you have bulbs)but you problably already did.... and grounds for sure !
Doublecheck fuses...sometimes it does not show immediately it is blown or not making contact correctly. After....trace all wires.
