76 2.0, was driving today and my fuse box relay board under the dash started smoking! I got the car home and pulled the fuse board down to find the far left relay's yellow wire into its base was melted. I believe this is the horn relay, and the horn doesn't work now. How do I get another base to replace the melted one? Btw, the car would not shut off with the ignition switch after this, I had to pull the coil wire to stop it. Is this a coincidence to the melted horn relay base wire, and what is that telling me? HELP!
