QUOTE(flat4guy @ Nov 25 2016, 12:00 AM)
I am guessing this is for the front only, do you have a pic where the bolt is or is it obvious?
It's at the rear of the torsion bars and it really isn't hard to find, pretty obvious. The rear height adjustment varies on the shock/spring assy, but it's usually an external snap ring that fits into the shock body below the spring perch. When you reinsert it up or down into a new slot the spring pressure will change, thus changing the the ride height. You want to be careful before reorienting the rear springs - there's a lot of stored energy in those puppies and it's easy to get, uh, surprised. There's a few different ways to make it safe so if you need to do it, ask around. Always someone here ready to help!
