Mikey914
Nov 15 2016, 06:53 PM
This is an "improved" kit that uses a slightly softer high temp silicone to seal the cover plate that joins the blower housing to the sheet metal portion of the heat exchanger on the bottom.
I have included 4 allen head screws with washers. These allow you to get good tension on the screw, and to remove easily without destroying the screw.
I can provide as cork if you prefer at the same cost, but This should be a reusable gasket that is now inexpensive!
Compare to
021256325A
and
021256326A
These go where the sheet metal attaches to the blower. The ones I removed were pitiful. Most are missing completely.
http://shop.914rubber.com/021256325A-02125...m?categoryId=-1
rhodyguy
Nov 15 2016, 07:00 PM
Nice mark. They used to be cost prohibitive elsewhere.
BeatNavy
Nov 15 2016, 07:33 PM
Nice Mark. I'm definitely in for a set. I need my heat this time of year
Rob-O
Nov 15 2016, 07:41 PM
I'll take a set right now. Working on the heat for my car right now. Had no idea these even existed!
Mikey914
Nov 16 2016, 12:05 AM
PMs sent
mzalanka
Nov 16 2016, 12:59 AM
Want.
Just got a new set of brackets from bstone.
Niklas
Nov 16 2016, 01:51 AM
3 sets for me.
jrblackbox
Nov 16 2016, 02:05 PM
Put me down for a set, Thanks
dlee6204
Nov 16 2016, 02:34 PM
1set
sdthomas
Nov 16 2016, 02:39 PM
I'll take one set!
brownaar
Nov 16 2016, 04:41 PM
1 set, please!
Mikey914
Nov 17 2016, 01:28 AM
PMs sent to all
TX914
Nov 17 2016, 08:51 AM
I'll take a set. Thanks.
porbmw
Nov 17 2016, 09:07 AM
I'm sure that my daughter's car will need one...and I probably do as well.
Two, please
pgollender
Nov 17 2016, 09:16 AM
A set for me too Mikey !
ndfrigi
Nov 17 2016, 10:16 AM
Sir Mike one set for me too.
iankarr
Nov 17 2016, 04:48 PM
I never even knew those existed! 1 set for me please.
JeffBowlsby
Nov 17 2016, 07:59 PM
I'm in for a set of the silicones. Let me know.
914Sixer
Nov 17 2016, 09:14 PM
I will take a set. Is there an update on the CHT senders or did I miss it?
rgolia
Nov 18 2016, 01:54 PM
one set for me.....
Mikey914
Nov 18 2016, 01:55 PM
PMs sent to all -
The CHT GB closed, but I
If you bumped the thread You should have got the code. It's possible I missed you, but I'll take care of you
Mark
brant
Nov 18 2016, 02:04 PM
Mark,
I need to get a set of these gaskets if the GB is still open
thank you
brant
jesse7flying
Nov 20 2016, 01:52 PM
I'm in for a set. Sent you a PM, but not sure you got it .Thanks
Jesse
smg914
Nov 20 2016, 02:49 PM
I'll take a set for the creamsicle which is currently missing these gaskets.
Can these gaskets be replaced/installed without removing the heat exchangers?
I'm thinking the allen screws might make it possible without removing them.
toadman
Nov 20 2016, 04:10 PM
I would like one set of these seals in silicone, please.
Mikey914
Nov 21 2016, 01:10 AM
PMs sent to all so far.
buck toenges
Nov 21 2016, 12:02 PM
I am a bit confused you have 3 different prices for these. You have 2 different numbers which I believe are for 2 different sizes and another price of $20.00 for a pair(?). Would you please elaborate?
Thanks,
Buck
Mikey914
Nov 21 2016, 12:10 PM
I have 3 different listings
one for the 021256325A gasket alone
http://www.shop.914rubber.com/021256325A-H...m?categoryId=-1One for the 021256326A gasket alone
http://www.shop.914rubber.com/021256326A-H...m?categoryId=-1And the one that should have been in the PM I sent with the code for all that bumped the thread - The Kit with screws
http://www.shop.914rubber.com/021256325A-0...m?categoryId=-1The discount code only works on the kit.
plas76targa
Nov 21 2016, 06:36 PM
Mike
Please count me in for one "Iimpvved kit"). Send a PM cost details.
Thanks,
Matt
QUOTE(Mikey914 @ Nov 15 2016, 05:53 PM)
Compare to
021256325A
and
021256326A
Shadowfax
Nov 21 2016, 07:03 PM
Please put me down for one also, Mark. Thanks!
P.S. Any way to combine this order with your upcoming Black Friday specials?
smg914
Nov 27 2016, 04:50 PM
QUOTE(smg914 @ Nov 20 2016, 12:49 PM)
I will answer my own question. Yes, these gaskets can be replaced without removing the the heat exchangers. The passenger side is a piece of cake. The drivers side is a little more difficult but the allen head screws really make the job much easier.
jim_hoyland
Nov 28 2016, 05:56 PM
Just saw this today.. I want a set too.
BTW: I showed my local Porsche mechanic your 1.8 Throttle Body gasket; he really liked it !
Mikey914
Nov 28 2016, 11:01 PM
PjMs sent to all
euro911
Dec 14 2016, 06:54 PM
Mark, I just saw this ... I was in AZ working on the new house and not on the board very much
I'd like to get two sets of these gaskets ... Too late for the discount?
I really need to go to the site and see what other great new items you've released recently
MartyYeoman
Dec 14 2016, 11:34 PM
Mark,
Please count me in for a set if still available.
Thanks, Marty
Mikey914
Dec 14 2016, 11:46 PM
euro911
Dec 15 2016, 01:26 AM
Thanks Mark ... I just sent in an order for a bunch of little goodies
MartyYeoman
Dec 15 2016, 01:52 PM
Ordered and PayPal sent.
Mikey914
Dec 15 2016, 02:10 PM
Left it open til Christmas for those that missed it.
barefoot
Dec 15 2016, 04:35 PM
QUOTE(Mikey914 @ Nov 15 2016, 07:53 PM)
Compare to
021256325A
and
021256326A
http://shop.914rubber.com/021256325A-02125...m?categoryId=-1What we really need are the meal cover plates that hold these seals. Most S tubes you can find are missing the caps.
euro911
Dec 15 2016, 05:42 PM
... and the little mouse trap doors that go inside
Mikey914
Dec 15 2016, 06:42 PM
QUOTE(euro911 @ Dec 15 2016, 03:42 PM)
Have a set working on these now.
