So I'm gradually sorting out the wiring mess the PO left for me, most the burned and patched wires are now gone on my '74 1.8. However one wire remains and I need help, not so much for its function but how it should be routed.
A yellow wire runs from front to rear from ignition to starter motor #50. it is part of the main loom as it passes through the cabin, between the seats and under the armrest it has been repaired & joined, it then continues under the inspection cover between seats and then disappears through the floor of the car to re-appear underneath, stuck in place with blobs of caulk it threads its way to the starter motor via the left valve cover and finally to the starter motor.
I'm assuming Porsche did not route the wire like this, so can someone guide as to how it should route? see photos
