QUOTE(stugray @ Nov 22 2016, 03:53 PM)
My first guess is rod knock.
But it could be:
detonation - have you changed the timing lately or was the engine running really hot?
exhaust leak - has a knock-type noise with associated "pfffft", but cant tell from video
loose engine tin - but this sounds "heavier" than a tin.
If you ever suspect bearings going bad, the first place to look is to take the valve covers off and look for metal flakes.
That is quicker/easier than draining the oil, but if you are due for a change?
I changed the oil and I did not notice any shavings. But the oil looked fresh when I got it. So who knows if there were any at that change. I have a feeling this car sat for awhile before I got it. Unfortunately I bought it from a dealer and don't have much info. They brought it from Arizona. Hope it's not rod bearings.
I believe the engine to be original to the car as well as the trans. Looks like the car has 83,000 miles on it and the motor looks like someone split the case in the past as there is red RTv sealant at some of the case bolts. Heads look a lot cleaner as far as oil and grime compared to the case. Maybe that's normal. I also have reason to believe the motor might have been upgraded to a 1.8 because of an old advertisement of this car someone saw a couple of years ago. They entered the VIN here when they saw it for sale and mentioned a few details of the ad. Not sure how to tell wether it's a 1.7 or 1.8. Case says it's a 1.7
