QUOTE(FL 000 @ Nov 23 2016, 12:08 AM)
QUOTE(HalfMoon @ Nov 22 2016, 08:55 PM)
QUOTE(FL 000 @ Nov 22 2016, 09:27 PM)
May not be what you want as an option but I had to perform alittle surgery on mine to get it to fit. I had to narrow it a bit and add some fiberglass to the ends. Still in work but you will get the idea from my pics.
Are you using the Sheridan flares or QRS bubble flares?
For my Sheridan lower valance, it looks like I'll have to
widen not narrow for fitment.
Could you clarify what flares your using?
Your lower valance does look like a Sheridan though...
TY
Sheridan flares and valance. My car had been rear ended at some point so not sure how the measurements match up with factory. How does the right side of yours line up? From your picture it looks like the curve of the leftmost part fits nicely under the quarter panel, and maybe you just need to extend the end an inch or so?
I can indeed get the right side to line up fairly well, but when trying to get the left side to line up it's off quite a bit....and if I force it forward it'll crack (in fact it already has a lil bit) as that forcing, forces it to "spread" apart way more than practical.
Pretty sure if I cut the thing right in half and add about an inch to the center section, it'll fit just fine.
I had hope mebbe I was just doing something wrong in terms of how the flares were originally installed, but that doesn't seem to be the case. Guess, I'll just cut it and add an inch :-)
