Spent Saturday re-installing front suspension; two questions:
1. I added the bump bushings when I re-installed the cross member, but WITHOUT loosening the steering columb lock nut.....sooooo did I just lower the cross member w/out affecting bump-steer geometry (i.e. do I need to loosen steering column to bring steering rack UP rather than just lowering the cross member as I believe is all that I accomplished)?
2. Had to raise gas tank a little to get 22mm swaybar to fit (replacing OEM bar). Should I pull tank and add somethimg to keep metal to metal contact, since tank is now resting on the bar?
Should be done next weekend.....
