QUOTE(dtkennedy930 @ Dec 8 2016, 06:30 PM)
QUOTE(Rsjg911 @ Dec 5 2016, 07:59 PM)
Barn fresh, 2 quarts of OEM blinker fluid for sale at $10/quart plus shipping. This will be enough for 1 car so hurry before they're gone!
I'm fairly new to 914s. I previously missed out on the sale of the Lucas Replacement Wiring Harness Smoke Service Kit (PN 530433), along with the very rare Churchill Tool 18G548BS adapter tube and metering valve needed for my '62 E-Type. Do you know if I can happen to use Porsche OEM blinker fluid as a substitute for the Lucas smoke replacement on my Jaguar? If so, will the Porsche OEM blinker fluid work with Lucas wiring and those bullet connectors? I've read the reverse is not true and that this Lucas smoke refill would also work only on Fiat and Alfa of the Magneti Marelli vintage, not when they switched electrical to Bosch.
Thanks in advance for the help.
http://www3.telus.net/bc_triumph_registry/smoke.htmClick to view attachment Click to view attachmentBe careful with that replacement Lucas smoke.
There are two different kinds, but they both have the same number.
There is the under dash smoke and the under hood smoke. They are not interchangeable, however for some reason either will work for taillight smoke from the rear.
Now don't confuse this with transmission tunnel wiring smoke, as that has a different color and part number.
I have not found a way around this problem ,except much as the rear brake parts on my GT6-MKIII, you have to order several sets and send back what does not fit.
