flmont
Dec 11 2016, 09:55 PM
How many 914's have a working trunk light..??
zambezi
Dec 11 2016, 10:16 PM
The lights have to be on for the trunk light to also be on, in case you didn't realize that. It will also be on the whole time the lights are on even when the trunk is closed.
Frankvw
Dec 12 2016, 03:11 AM
My trunklight did not work, but after fixing my licenseplate-lights and instrument-light, it worked again as well as a bonus. So, yes, I have a working trunk light ! :-)
dlee6204
Dec 12 2016, 07:51 AM
My trunk light not only works but I also added a second one on the passenger side of the car. I don't use it for the trunk as much but more for lighting in the engine bay. It's great when you break down at night... not that I do much of that.
jor
Dec 12 2016, 12:27 PM
A prior owner had painted over mine. After scraping the paint off, I found the light and I also found that it works. It took a few days for this slow poster to figure out that the trunk light was tied to the headlights .... doh!
Dec 12 2016, 12:35 PM
QUOTE(zambezi @ Dec 11 2016, 08:16 PM)
forrestkhaag
Dec 12 2016, 04:21 PM
Mine works and feeds an even bigger engine bay light necessary for midnight to 6am roadside pullovers for strange engine noise investigations and/or the occasional reattachment of the oil filler cap or dipstick, or to dislodge a screwdriver from between the engine tin and the rubber seal, or to alleviate vibrations due to a stray spark plug riding around the ferris wheel of the fan......
Or yeah, and to illuminate and get the warmed tinfoil wrapped food that cooked at 90 (and I don't mean degrees) to a perfection between Flagstaff and Tucumcari............
flmont
Dec 12 2016, 05:24 PM
Thanks Zambezi,...I did NOT know that,..But I shall ck it out tonight,...FM
pete000
Dec 12 2016, 07:05 PM
Mine works on both my 914's
mark04usa
Dec 13 2016, 12:06 AM
My trunk light hasn't worked in 40 years. I should add that to list of things to fix, but it will probably stay at the bottem of the list for a while, since the bulb is not at fault.
Coondog
Dec 13 2016, 06:13 AM
Mine works, but interior light doesn't.....
DRPHIL914
Dec 13 2016, 07:11 AM
mine works, has since I took ownership of the car.
Shadowfax
Dec 13 2016, 08:58 AM
Mine works too.
whitetwinturbo
Dec 15 2016, 12:59 PM
............this question infers one can open their trunk
