jim_hoyland
Dec 12 2016, 04:53 PM
I'm going to enlarge the fog light switch hole; ignition switch will be installed there . Question is can I remove the left side dash face without pulling the steering assembly. I've read that the late (75 - 76 ) dash faces differ from earlier years. Currently the dash face is covered with leather.
Picture shows the area; not using the 911 switch, but plan to use sixnotfour's modified 914 switch.
whitetwinturbo
Dec 15 2016, 01:06 PM
sixnotfour
Dec 15 2016, 04:47 PM
The 76 piece ,is very flexible ,,I made a pilot hole , then pulled it away and enlarged the hole to what I liked..scary stuff ..
sixnotfour
Dec 15 2016, 04:58 PM
this was the first trim , I have since enlared it more like on OG six.
Jim, its way easiest to doit all at once..
Mikey914
Dec 16 2016, 02:15 PM
As you can see from the metal, unless you cut it (which you could do) you would have to do at one time. I think you could do it.
The early, late and the one we make shown
jim_hoyland
Dec 16 2016, 03:50 PM
QUOTE(Mikey914 @ Dec 16 2016, 12:15 PM)
