Replaced all the rubber on the car with Mikey's 914 Rubber components. Car is a '74 2 liter with late doors. After assembling all the rubber and door components I can't seem to get the window adjusted to keep the top rear from impinging with the Targa seal. It sticks and needs me to push to get it started. Working with the Haynes manual and have taken all the adjustments I can. I see that there is a bit of space in the triangular window, at the top, that if removed should allow the needed gap for the wind up window. It's winter here and even though my garage is heated I can't seem to move the seals on the triangle window. Do I have to wait until the heat of summer to soften up the seals to get them to move the distance required ?? I've attached a couple of pics but don't know if they show the gap in sufficient detail.
Click to view attachment Click to view attachment
