iankarr
Dec 14 2016, 12:25 PM
Hi Guys,
Trying to make good on my new years resolution to stop leaks on my 2056. I replaced the oil pump cover gasket (it was partially disintegrated).
In Jake's DVD, he recommends using the red sealing-type nuts on the oil pump cover. Looks like they're still available from air-cooled....but are they the only way to go? Or can I use something like teflon paste on the studs?
Thanks!
Ian
McMark
Dec 14 2016, 12:48 PM
Nope, never use them on any of my builds and they weren't spec'd from the factory.
iankarr
Dec 14 2016, 02:06 PM
Thanks, Mark. Do you use teflon or anything else to keep oil from seeping past the threads? It's under pressure, no?
McMark
Dec 14 2016, 02:16 PM
It's only under pressure if the rest of the seal leaks. Which is a more complicated way of saying, No, it's not under pressure. I don't put sealant on the threads. But you can if you want. It's not gonna hurt anything.
iankarr
Dec 14 2016, 02:18 PM
Ah. Makes sense. Thanks!
