I have intermittently seen oil accumulations on the top of my 4 2.2L block / Then eliminated them with a reseal of the oil filler gasket. Use Yamabond on both sides of the cork gasket and away it goes. Same thing for the pushrod seals / They do not seal unless a sealant is used - or if they do, only for a while. The Japanese high rev motorcycle market figured this out a while back when at 10K and only air cooled, a sealant is sometimes needed.
New cheap cork gasket and pushrod tube o-rings and a tube of Yamabond will solve most of your worries. but not all.....
Sidebar: If someone tells you a tale of a non leaking type four, it is a tale of a time well past. Do not buy land from him. Do not date his sister. And,... do not expect his repairs to be permanent or effective.
Keep in mind that in the forty's the German's believed they would own Saudi Arabia and have a permanent supply of cheap oil / hence the Desert Porsche.
I have been driving and wrenching Porsches for over four decades / from 356's to 996's to 911's and 914's... to, well,..... you get the picture......... they all leak. My C4S leaked. My 993 leaked. All other 911 and 914's leaked. Porsche invented the oil pan with capacity between blue-blood service intervals at the dealer to hold the drips.... I am working on a 914 oil pan in carbon fiber / but the cost outweighs the concern. live with it and drive at maximum enjoyment whenever possible.
