tornik550
Dec 17 2016, 07:30 PM
I have a backup set of /6 headers that have some dents. The dents are on the curved areas. I am sure that air flow would be reduced with these dents. On one of the dents, I drillled a small hole on the opposite side, heated the pipes, stuck a small solid metal rod through the hole and tried to pound out the dent. I was able to remove the debt however the area is now fairly rippled. I don't think I can flatten it would more without making a bigger hole which would be much more difficult to weld shut.
The ripples are not horrible however you can definitely see them. Should I just leave the ripples or is there some other way to fix the issues? If it were on a straight pipe, it would be easy to weld a new pipe in its place however not easy on the curves.
colingreene
Dec 17 2016, 07:53 PM
post pictures.
often times the small dent will do almost nothing performance.
tornik550
Dec 17 2016, 08:21 PM
The two debts arrowed in red are the problems. I'm not worried about the green one since it's on a straight. I can fix that one.
rick 918-S
Dec 17 2016, 09:03 PM
I would us a torch and a rod slid down the pipe to push It out. Or cap the opening and put about 125 psi of air in the tube and heat it with a torch. It may expand. Just be ready to cool it off so it doesn't blow out the tube.
falcor75
Dec 18 2016, 07:05 AM
tornik550
Dec 18 2016, 07:06 AM
QUOTE(falcor75 @ Dec 18 2016, 08:05 AM)
Wow. That very surprising.
mb911
Dec 18 2016, 07:07 AM
So the secret in the exhaust industry is to cap the ends and pressurize the tubing to about 10psi. Then heat with an oxy torch and the dents will pop out..
I have don't this tons of times and have done it On front oil cooler lines for 911s many times as well.
PlaysWithCars
Dec 18 2016, 10:22 AM
QUOTE(falcor75 @ Dec 18 2016, 05:05 AM)
So mandrel bent versus cheaper header construction? No difference? Really surprising given the amount of marketing and premium prices associated with mandrel bent headers.
