QUOTE(bowzer @ Dec 18 2016, 03:52 PM)
what ive come up with is that the injector points and the injectors are getting no power.good spark at dist,fuel pump is pumping but the injectors arnt opening.also, is the pump supposed to run full time?
The fuel pump should run for 1.5 seconds when you turn the ignition key from off to on. This is to pump up the FI pressure.
Does the FP run for 1.5 seconds after the key is turned on?
When you turn the key from ON to START, as the engine turns, the extra contacts on the distributor open and close indicating to the FI ECU the engine is turning so the ECU turns on the fuel pump full time (while the engine is running).
These extra distributor contacts also drive the pulses to the injectors. If these contacts are not opening/closing with engine cranking, you won't have pulses to the injectors or the fuel pump running.
