QUOTE(mbseto @ Dec 20 2016, 06:52 AM)
Seems like you need to pick a role before you'll get sensible opinions: would you rather drag race or drive on the street?
What kind of motor, btw?
90% street car, 10%
Nissan VQ30de (Maxima) -upgrade VQ35de (350z w/FWD IM & cable TB & Nistune)
QUOTE(jd74914 @ Dec 20 2016, 09:26 AM)
Chris-I think your spreadsheet is calculating tractive force incorrectly; it appears to be missing the final drive ratio in the calculation.
Does your torque curve really look like that? It's pretty flat. If you are down any torque at the low end (from expected) and go with the taller 3-5 you might find the car sluggish right after shifts.
Bradhole created the file and posted it. I've just made changes as needed. Yes, what's that formula supposed to be?
That chart still references the original data on page 1, an 8000rpm -6. I'll post flat in a bit
QUOTE(Mark Henry @ Dec 20 2016, 02:04 PM)
As far as a 5th gear H is concerned I think you are missing the point, it's used for a 3000rpm 80 mph highway economy gear with a big engine...not for going 200mph.
Exactly.
QUOTE(stownsen914 @ Dec 20 2016, 02:46 PM)
Take the advice about beefing up your trans if you are planning to put close to 300 ft-lbs through it. As you probably know, many would say that's above the threshold of what a 901 will like. Treat it gently, especially in 1st, and no launches.
Scott
Calculating the cost of the X gear + billet upgrades + at the limits makes engineering an adapter to the WRX trans seem smarter.
The seals are leaking pretty bad so I figured I'd look into my options while I'm there. Feels like the stock ratios would be the better fit with the 3.0L.
