ChrisReale
Jun 26 2003, 08:51 PM
Thanks to the club who hosts the info, and demick for writing it up. It was very easy to do.
Bleyseng
Jun 26 2003, 09:02 PM
Great, you'll be able to use them for the next Autocross when its raining.
Geoff
ChrisReale
Jun 26 2003, 09:37 PM
QUOTE(Bleyseng @ Jun 26 2003, 08:02 PM)
Geoff
Yea....
Bruce Allert
Jun 26 2003, 09:42 PM
Chris, do ya still have yer high beam indicator lite? I switched the wrong 2 wires & lost mine. Fogs work independent but no blue lite. Gotta do dat sum dey!
bruce
ChrisReale
Jun 26 2003, 09:44 PM
I dont think me high beams even work, but I think I did loose the indicator. Oh well....
Bleyseng
Jun 26 2003, 10:03 PM
You guys are ahead of me, my fogs still don't work.
Geoff
Bruce Allert
Jun 26 2003, 11:47 PM
Me thinks the 3 of us should get together & do fogs & syncros... what say ye???
bruce
Dave Cawdrey
Jun 26 2003, 11:57 PM
me thinks me lonely...
Demick
Jun 27 2003, 08:38 AM
You should not lose your high beam indicator light. If you did, then the problem was with the conversion step #2.
If your car is a '70 or '71 4 cyl, then you probably followed the instructions for another year and used the wire from the fuse panel instead of the combination relay.
If your car is a '72 or '73 4 cyl or a -6, then you used the wrong white/blue wire from the #1 fuse (there are 2 attached at the same point, and you need to figure out which is which).
If your car is a '74 - '76, then you also used the wrong white/blue wire from the #1 fuse. There is actually a white/blue wire attached to each side of the #1 fuse. You need to select and ground the one that was attached to the input side (toward the rear of the car) of the #1 fuse. If you chose the wire from the output side (toward the front of the car) of the #1 fuse, then you grounded the high beam indicator and did not do anything to affect the fog light operation. I need to be more clear about this in the instructions, so I will get them updated. Sorry about any confusion.
Demick
'74 2.0
Bruce Allert
Jun 27 2003, 09:11 AM
I know which wires they are now and just have to take 10 min. to make the switch. (just call me a procrastinator!)
bruce
ChrisReale
Jun 27 2003, 12:56 PM
I just checked and I still have my indicator light.
Bruce Allert
Jun 27 2003, 01:03 PM
bruce
