It's unlikely that the starter is the problem. It's so quick and easy to hook it to a battery to see if it turns. Why would you throw money at it before doing a couple simple tests so you know what to fix?
My first 914 suddenly quit turning over. First thing I did was grab a screwdriver and jump the terminals at the starter to see if it would crank. It took literally a minute (most of that time was retrieving a screwdriver and making sure the car was in neutral with the ebrake on
). I instantly ruled out the starter. In my case it was the plastic housing of the ignition switch that cracked (a fairly common failure on these cars).
I'd strongly suggesting you do the quick tests first so you can narrow down where to focus your troubleshooting. Check the starter first because it takes no time. Then circuits / grounds / switch.
