1973Porsche
Dec 23 2016, 04:46 PM
Tom_T
Dec 23 2016, 04:50 PM
Restoration Design (vendor on here) makes good repros of all the pans & cross-members, etc. that you'll need.
http://www.restoration-design.com/store/SFNTGood Luck!
Tom
tygaboy
Dec 23 2016, 06:42 PM
Get all the tar off the floor before you panic. A lot of that looks like it may be surface rust that won't necessitate replacing. A wire wheel is your friend.
Best of luck and keep the pics coming!
BeatNavy
Dec 23 2016, 07:03 PM
QUOTE(tygaboy @ Dec 23 2016, 07:42 PM)
You may be able to get away with replacing small sections rather than the whole pan. Replacing the whole pan is not a trivial effort. Depends on what your goals are, and how bad the rot really is...
sixnotfour
Dec 23 2016, 07:07 PM
Dec 23 2016, 07:37 PM
Grab a multi tool and the tar will come off quickly. A knotted wire wheel will get the rust off. (Wear eye protection) Then you can see what you have. Don't panic! Almost every 914 needs some rust repair in the floors and often times other areas. As the guys above said, you might not need replacement pans and you can get the above tools at harbor freight for $30-40. When you get the tar up post the result and we'll figure out the next step.
euro911
Dec 24 2016, 01:16 AM
with what's already been said above.
sixaddict
Dec 24 2016, 10:25 AM
Pretty sound advice so far but here is my two cents
A heat gun helps with removing tar.......heat .....scrape...fun project but then you will have clear picture of damage. And pull remainder of carpet from longs...
Second have a shop experienced with 914 repairs to do your metal work as fixing it wrong will detract from your cars value. Too many body shops will tell you they can handle it but will not. That is assuming you are not doing it yourself. Decide if cost to repair is within your budget.
Good luck
jmitro
Dec 24 2016, 11:57 AM
agree with advice above. Based on the photos, I wouldn't be surprised if your rust repair involves more than the floorpan. But you will only know by removing tar pads and vacuuming up the debris
McMark
Dec 24 2016, 05:12 PM
Welcome to the slippery slope.
remove all the tar, the side carpets and the back sound pad to see what's really there.
1973Porsche
Dec 24 2016, 10:40 PM
rjames
Dec 26 2016, 11:41 PM
Before you commit, check the rest of the car for additional rust issues.
How do the rocker panels look? The hell hole(below the battery tray) and rear suspension ears?
Amphicar770
Dec 27 2016, 12:19 PM
Before you start learning to weld on your car, take a class or workshop at the local vo-tech or similar. It will save you a lot of time and money in the end.
Also, do not use flux core welder (assuming you are doing MIG). Your welds will be crap without gas.
jmitro
Dec 27 2016, 12:56 PM
with both of the above posts. car may not be worth your time and effort to save unless you just want a long term project. My project looked the same as yours. it's taken 15 months to get all the sheetmetal replaced (doing it myself)
mb911
Dec 27 2016, 02:10 PM
My project is going on a year but it only when I have a few minutes here and there. I enjoy the long game so it works perfect for me.
That's all savable but you need time.
slotty008
Dec 27 2016, 04:51 PM
QUOTE(mb911 @ Dec 27 2016, 09:10 PM)
A lot of time and patience. Check out the firewall and the centre tunnel for rust . I had a lot of it. Now finally fixed after 11 months of work. And still 2 full pages of repairs to do . For the moment. But that's part of the fun.
