I installed the throttle hand lever last night and then tried to test fit the appearance group console tonight. I found that the throttle lever is too far forward to work as designed with the console.
Has anyone run into this situation before and found a solution?
I am considering turning the throttle lever around 180 degrees but I am not sure yet if this would work correctly or not. Too tired tonight to figure anything out but was hopeful someone had dealt with this already.
Jeff B
