PCA7GGR
Jan 6 2017, 01:25 PM
I've got several "early" and "late" steering wheel hubs.
Let me know if you need either. Also, I would appreciate it if someone could let me know which is considered
- early ('70-'71?) and which is considered "late" ('72-'75)
and what hub attachment
- with wire prong
- without wire prong
goes with which hub. Thanks
Click to view attachmentClick to view attachmentClick to view attachment
euro911
Jan 6 2017, 01:45 PM
I believe late is considered 73 and up
Jan 6 2017, 02:11 PM
Wire prong -late
Metal cancel tab on hub - early
Late is actually '72 and later. Changes from 10 to 11 on end of part number on steering wheel and goes from flat to a bevel on the face. Early fits 911's without mods.
PCA7GGR
Jan 6 2017, 03:24 PM
Great - so which hub (deep vs shallow) goes with which? Thanks
Jan 6 2017, 05:37 PM
Early Flat hub wheel, ends with 10 - metal tang on hub- no wire prong
Late dished hub wheel, ends with 11- plastic cancel tang on hub- wire prong for horn wire.
PCA7GGR
Jan 6 2017, 05:53 PM
So if I've got this right:
- deep hub with steel signal cancel tang and hub without tang for wire
Early '70-'71 with ".10" steering wheel
-short hub with brass horn contact/plastic signal cancel tang and hub with tang for wire:
'72-'76 with ".11" steering wheel
Thanks all for your helpful input.
Jan 6 2017, 06:09 PM
OMG.
socal1200r
Jan 6 2017, 10:48 PM
So from reading another thread about steering wheel adapters, one guy got his Grant steering wheel to fit by removing the stock steering wheel hub then drilling it out to fit the Grant wheel. So basically the Grant wheel was bolted to the hub, then the hub was fit over the splines and secured with the large nut?
If that's the case, then one of those hubs should work as an adapter for my '73, most likely the shallow one?
