Jeroen
Apr 28 2005, 04:37 PM
not my own (obviously
) trying to help another teener...
tailshifter on accel pops out of first gear
is it a linkage problem or sumptin inside the gearbox?
Eric_Shea
Apr 28 2005, 05:32 PM
Mine hasn't done that for years
Tell him to put it up on jackstands. Cures the problem every time! I'd say shift fork adjustment??
TravisNeff
Apr 28 2005, 05:49 PM
Adjust the clutch, check the transmission mounts (mine were all loose), adjust the linkage. Watch out for dog food in the tunnel
Brad Roberts
Apr 28 2005, 07:09 PM
It can be all the above.. but:
if the slider is worn out...it will pop out
if the synchro band is worn out.. it will pop out
if the dog teeth just barely exist.. it will pop out
Any combination of the above will cause it.
B
jim_hoyland
Apr 28 2005, 07:19 PM
I've got the same issue, but stays in gears if I gently hold the shift lever while in first.
Any recommendations for inspection/repair ?
Brad Roberts
Apr 28 2005, 07:29 PM
It is either the synchro ring (75.00) or the slider (575.00) Typically is it both. But you might get away with the ring. Bare min.. replace the dog teeth and the synchro ring. Once it comes apart..you'll know if you have to replace the slider. Look for worn teeth on the dog teeth and slider.. we have pics when you are ready.
B
Dr Evil
Apr 28 2005, 07:31 PM
Exactly what B said. Jim, I could help you out maybe. PM me and we can talk.
