My car was sandblasted to bare metal inside and out. I used Eastwood After Blast.....supposed to be a cleaner and also etches with phosphoric acid. Will be priming with an epoxy primer.
The problem is now there is a chalky white residue in many areas that has to be scuffed off. This is going to be a much larger time committment than I anticipated.
http://www.eastwood.com/eastwood-afterblast.html
According to Eastwood, I should be able to prime without any further prep, but obviously this will not work.
Any suggestions about removing the residue and prepping for primer?
