QUOTE(stugray @ Jan 10 2017, 12:01 PM)
My car currently has an LED indicator for the ALT LIGHT.
It DOES work, but not by itself.
You have to put a ~70 Ohm high power (~1watt) resistor in PARALLEL with the diode.
One thing above that IS correct about Diode indicator: The stock incandescent bulb will light up if the Battery is "bootstrapping" the field winding in the alternator (key on but engine not running) OR if the Alternator has a much higher voltage than the Battery.
This is because current can flow both ways in the incandescent bulb and it will illuminate either way.
If you use the LED, then it will only illuminate in the first case (Battery providing current to field winding), but will not illuminate in the second case.
There are some LED indicators that will illuminate with both polarities, but I cant recall where I saw them.
Thank you, it works perfectly
