In my continuing research on recommended float level, I conclude that the typical recommended gap between the top of the floats in our twin 40 - 44 Weber carbs and the under machined surface of the carb tops should be 10 mm, when the tab is gently resting on the small valve spring - thus not depressed.
Two additional issues appear in the postings: 1) a difference between the earlier floats (brass floats?) and the black compound floats now common in these carbs, and 2) the importance of having both floats adjusted to the same gap (may need some careful bending the metal bracket holding the floats together):
1) One opinion was that the later compound floats need a gap increase of 2 to 3 mm, i.e. gaps of 12 to 13 mm. Intuitively this is logical if these compound floats are less buoyant than the earlier floats (are they?).
2) I found it relatively easy to get the float gaps the same on both floats by gently bending the bracket.
Comments/advice is always welcome.
