QUOTE(Mark Henry @ Jan 20 2017, 09:50 PM)
Remove the flywheel, dig the grease out of the holes on the backside, get the proper size pin punch and knock them out.
Heck I've done it with a nail that I've ground the point off flat.
Easy peasy !
OMG....there's a proper way to dood it.
Hmmmm.... flywheels are on the shelf, I don't remember the holes going all the way through. That would be MUCH easier! If that doesn't work I think I'll need to find a torch. I do have a ton of old drill bits, worst case scenario I could probably cut some of my own dowels from the correct bit size.
