grasshopper
Apr 30 2005, 12:28 PM
what order do all the pieces go on?a diagram anyone? and not for now, but later, what is a good aftermarket tranny mount? Thanks everyone
CptTripps
Apr 30 2005, 12:45 PM
I won a set of the Wevo mounts at WCC. SWEET stuff...I can't wait to get them on. When I *DO* change them out, I'll take pics of how I pull everything off, and post here if you want.
grasshopper
Apr 30 2005, 12:57 PM
QUOTE (CptTripps @ Apr 30 2005, 10:45 AM) |
When I *DO* change them out, I'll take pics of how I pull everything off, and post here if you want. |
that would be great! thanks
Bleyseng
Apr 30 2005, 01:08 PM
Just use the 911 engine mounts as they fit with a bit of ovaling on the bolt holes.
anthony
Apr 30 2005, 01:30 PM
And the "sport" version of the 911 engine mounts are a little cheaper. I just replaced mine. Pretty easy job.
Aaron Cox
Apr 30 2005, 04:23 PM
im young....
i went with delrin-ish style solid mounts
dont bother me none
URY914
Apr 30 2005, 07:56 PM
QUOTE (Aaron Cox @ Apr 30 2005, 02:23 PM) |
im young....
i went with delrin-ish style solid mounts dont bother me none |
Smart guy, Aaron
Paul
Aaron Cox
Apr 30 2005, 08:56 PM
QUOTE (URY914 @ Apr 30 2005, 06:56 PM) |
QUOTE (Aaron Cox @ Apr 30 2005, 02:23 PM) | im young....
i went with delrin-ish style solid mounts :D dont bother me none ;) |
Smart guy, Aaron
Paul |
thx again paul,
happy to buy parts second hand....in this case, 'race proven'
TMorr
May 3 2005, 11:02 AM
I won a set of the Wevo mounts at WCC. SWEET stuff...I can't wait to get them on. When I *DO* change them out, I'll take pics of how I pull everything off, and post here if you want. |
Doug thats great, hope you like them. Look forward to seeing the pics.
Who won the other pair?
Tracey
Dave_Darling
May 3 2005, 12:02 PM
QUOTE (grasshopper @ Apr 30 2005, 10:28 AM) |
what order do all the pieces go on?a diagram anyone? |
Check Haynes. The pics in the first section of the tail-shift outboard motor mount bar mountings should give you a decent idea. The lower-left pic on p. 18 (unlabeled in my copy), pic 1.10. a) "Engine mountings,". There are also pics of the transmission mounts, e.g., 1.10. b) "Transmission mountings" and 5.18 "Transmission mounting".
On top of the ear, the curvy metal washer sits. The notch goes over the ear. The rubber part of the mount sits on the curvy metal washer. The flat metal part with the bent-up edges goes on top of that, then I think a washer and then the bolt-head.
Under the ear, you get the great big thick metal washer, and the nut.
--DD
Brad Roberts
May 3 2005, 12:43 PM
QUOTE |
Yeah.. who won the other pair ?
B
