just 6 bolts ...
1) jack car up has hign as possibe. evenly.
put jack-stands under the control arms where they connect to the body.
2) disconnect harness from relay board and brain.
fuel pump wire etc.
3) disconnect hoses, like gas lines (including breather lines if you have them, vacuum lines etc.).
4) disconnect clutch, speedo and accel cable.
5) disconnect shift-rod on the firewall, leave rod hooked up to the tranny.
6) disconnect heater tube and heater cable
7) leave everything on the engine/tranny. (like exhaust etc.)
8) disconnect tranny groundstrap
9) disconnect transaxles on tranny (4 bolts each side)
10) put a jack under the engine, around the oil-drain plate.
(put some plywood inbetween, thin 2 x 2)
11) remove 6 bolts. 2 on the engine mount bar, 4 on the tranny. (unbolt the tranny mount on the body, that way it's not in your way when you slide the engine out).
12) lower the whole thing and slide out the back
if you can't get the car high enough because you only have small jacks, remove the air filter/carbs if they are in the way.
or, if you can, remove the rear valance to get the clearance to slide the engine out on the back.
also, you can take the jack out under the engine once it's lowered and just slide the engine/tranny out by itself.
that also gives you some more clearance.
after you did that once or twice, you can do it in 15 minutes
PS: assembly is the reverse ...
Andy
