Aaron Cox
Apr 30 2005, 05:02 PM
for use with 205/50 15's (essentially 9.1% geared down)
just contemplating...., stock ZD is too short for socal freeway driving...., H is too tall
working on my 'wonder box'
1- A
2- F
3- ZD flipped
4- V
5- HA flipped
rhodyguy
Apr 30 2005, 05:16 PM
what? try driving 70 instead of 90.
k
Aaron Cox
Apr 30 2005, 05:18 PM
QUOTE (rhodyguy @ Apr 30 2005, 04:16 PM) |
k |
If I only could.....car gets crazy loud at 4k in a commute
need a slightly taller fifth
BTW, speed limit down here is 70 in most places, traffic is 80-85
ArtechnikA
Apr 30 2005, 05:24 PM
PowerHaus-II shows a HB ( HB 19:31 1.63 ) gear. Charlie Davis' gear chart has an open spot where HA would be for a 901 box, so i donno if they "really" exist.
but try PowerHaus-II and see what they say. then report back...
Joe Bob
Apr 30 2005, 05:28 PM
POWERHAUS=$$$$
The H is only 4-5mph difference at 3500 rpms...that gonna kill ya?
Aaron Cox
Apr 30 2005, 05:36 PM
Flipped HB...
final speed output is 9.1% lower with 205/50 15's (essentially 9.1% geared down)
Aaron Cox
Apr 30 2005, 05:39 PM
just thinkin aloud.....
BTW, what is an HB gear set out of?
ArtechnikA
Apr 30 2005, 05:44 PM
QUOTE (Aaron Cox @ Apr 30 2005, 06:39 PM) |
...what is an HB gear set out of? |
this one should be pretty easy :-)
we know it's not a 914 ratio, therefore the answer is "some kinda 911 or 912 prior to 1972." you'll need to spend some time with ETKA, i think, to run it down - this is your project, not mine.
just pray it's not a 911R ratio...
Aaron Cox
Apr 30 2005, 05:49 PM
QUOTE (ArtechnikA @ Apr 30 2005, 04:44 PM) |
QUOTE (Aaron Cox @ Apr 30 2005, 06:39 PM) | ...what is an HB gear set out of? |
just pray it's not a 911R ratio... |
thanks for the laugh
BTW- what is etka
ArtechnikA
Apr 30 2005, 06:14 PM
QUOTE (Aaron Cox @ Apr 30 2005, 06:49 PM) |
what is etka |
Ersatz Teile Katalog, Electronische
(Replacement Parts Catalog, Electronic)
also called 'PET' here and there...
propricer
Apr 30 2005, 06:42 PM
HB was the 2nd gear in the 901/06,10 and 12 as well as the 905/00,01 and 13.
HA was the 2nd gear in the 901/53,54,78,79,83 and 84
Aaron Cox
Apr 30 2005, 06:44 PM
QUOTE (propricer @ Apr 30 2005, 05:42 PM) |
HB was the 2nd gear in the 901/06,10 and 12 as well as the 905/00,01 and 13. HA was the 2nd gear in the 901/53,54,78,79,83 and 84 |
thanks mr ducey.
BTW- second gears are fixed to the shafts i thought....
bondo
Apr 30 2005, 06:55 PM
QUOTE (Aaron Cox @ Apr 30 2005, 05:44 PM) |
BTW- second gears are fixed to the shafts i thought.... |
Yup, that's bad news. Might not be available in a standard form. The H gear is easy, it's second in a 4 speed, and on the 4 speeds it's first that's fixed to the sahft.
propricer
Apr 30 2005, 07:17 PM
Just took an HB out of a 905/13 and it wasn't fixed to the shaft.
ArtechnikA
Apr 30 2005, 07:20 PM
QUOTE (propricer @ Apr 30 2005, 08:17 PM) |
Just took an HB out of a 905/13 and it wasn't fixed to the shaft. |
905 is a SportoMatic (and therefore 4-speed) - yes ?
skline
Apr 30 2005, 07:22 PM
I suggest you get the body work and paint done before you go changing any other mechanical stuff in your car. You are always complaing how it looks, stop worrying about the go faster parts and make it look good. Actually, it doesnt matter how it looks or runs, I am still going to spank you at the next AX.
propricer
Apr 30 2005, 07:29 PM
Yes, 905 is a 4-speed sport-o-matic ... also has the VERY rare 7:27 R&P !!!
0396
Apr 30 2005, 08:05 PM
Aaron,
I have a slightly used HA. Bought it years and years ago for
my 901 with a 904 mainshaft.
I was going to give it to an old friend of mine- Topper C.
for his collection.....but what's it worth?
Joe Bob
Apr 30 2005, 08:25 PM
I paid 150 for my H gear while some freak on ebay got 500....
redshift
Apr 30 2005, 08:41 PM
You have 15 inch wheels? Why not go to 16s, and go up to stock rolling diameter?
See, I detest nerf tires, and you should too, although I know you like that frame rail on cement feel.
M
Aaron Cox
Apr 30 2005, 08:59 PM
like i said...just thinking aloud.
i have a trans in pieces taht will go back together this summer. the 'wonder box'
i have no idea what a HA goes for
redshift
Apr 30 2005, 09:03 PM
Have three, for free!
HA HA HA
Now, go get big tires!
M
TimT
Apr 30 2005, 09:22 PM
Aaron, somtihing isnt making sense with you gear choices.
A,F is a popular first second combo
ZD is a K if flipped I believe
A,F,K
is a good combo...
but going form a K to a V in an upshift will cause your RPMs to drop way to much
If you want to build a street box, you can have bigger rpm drops between gears.. or build a 5 speed box with 4 close ratio gears, and an overdrive 5th...
I dont see that in what you have posted.. though I may be missing something.
Aaron Cox
Apr 30 2005, 09:27 PM
QUOTE (TimT @ Apr 30 2005, 08:22 PM) |
A,F,K
is a good combo...
I dont see that in what you have posted.. though I may be missing something. |
that precisely waht i would like to do.
1- stock
2- stock
3- flipped 914/4 5th
4- stock or something shorter
5 'overdrive' as in flipped HA gear
5th gear choices
Flipped HA 32 : 20 (0.625)
ot
ZD 31 : 22 (0.710)
TimT
Apr 30 2005, 09:31 PM
hehe
The box you want to build is a AFKQ...ZD any stock fifth will work. taller would be better.. Ill check my box-o-gears tomorrow
Ive sold traded some lately
Aaron Cox
Apr 30 2005, 10:07 PM
for tim
MattR
Apr 30 2005, 11:07 PM
Nice chart! Can you send it to me?
redshift
Apr 30 2005, 11:13 PM
Look for another, as I will want one too...
No way I am going to have Aaron faster than me.. on paper.
M
redshift
Apr 30 2005, 11:15 PM
You are going to find out some funny things about horsepower when you start shifting 3-4-5-4-3 the first few times..
HAHAHA
M
MattR
Apr 30 2005, 11:30 PM
Miles, it was an inside joke. I sent aaron the gear chart.
Aaron, just get a nice -6. Dont mess with your -4 anymore!
redshift
Apr 30 2005, 11:34 PM
Yeah! Get a /6, so you can cry with the big dogs!
M
ClayPerrine
May 1 2005, 07:32 AM
QUOTE (Aaron Cox @ Apr 30 2005, 05:39 PM) |
BTW, what is an HB gear set out of? |
You have exactly described the gear rations of the transmission that is in my /6 conversion .
If you want those ratios, find a 901-00 with the pull type clutch. It's a 4 speed, and it comes with all that and a A geared mainshaft to boot!!!
