Hi, thought I'd list here first before Craigslist.
1974 Porsche 914
vin # 4742919103
Located in Altadena, CA 91001
See here for Pictures.
Porcshe 914 for sale
Purchased my 914 years ago but have a family now and don't have time to give it the deserved attention. Runs.
Work performed by previous owner:
- Front suspension from a 1989 911 Carrera (larger torsion bars, larger ventilated disc and calipers, large sway bar, and an aluminum steering rack mount)
- Re-drilled hubs in back
- Rebuilt the rear trailing arms and cv axles
- New wheels bearings were installed along with poly-graphite trailing arm bushings
- Repacked axles
- Epsilon 3-piece wheels
- Rebuilt fuel tank
- Rebuilt pedal box
- New main window seal was recently installed
- Dynamatted
- Factory option center gauges
Work I've done over the past few years.
- Push-rod tube seals to resolve oil drips
- Stainless steel fuel lines
- New main targa seal
- Purchased a nice replacement targa top with all hardware and seals
- Replaced cap, plugs, wires.
- Installed Ignitor Electronic Ignition
- New Battery
Things that are included that should be installed.
- I am including a Bursch exhaust along with a very nice Triad exhaust that want to be installed. (There is a less than impressive exhaust on it now)
- Full Carpet kit (new)
- Fiberglass FlexDam from 914 Rubber http://shop.914rubber.com/914-Fiberglass-f...ubber-914FD.htm
- Many additional parts
There's also two large bins with parts that will be included with sale.
I am looking for $6000 dollars cash or cashiers check that can be cashed locally. I am somewhat negotiable if you are serious. Thanks for looking.
John
