Several years ago I replaced my standard headlamp bulbs with 100w bulbs. It seems that whenever I drive the car with the headlights on and come to a stop my voltage gauge goes well into discharge territory. Once I get moving the gauge returns to the charging side. This is really a problem in stop and go traffic with the headlights on. The alternator is a rebuilt Bosch unit standard for 914 and was replaced about 5 years ago. I'm thinking of replacing the headlamps with an HID set-up to reduce the load. Is this an alternator problem? If I run the fog lamps or put on the turn signal while stopping, the system discharges. Thoughts are welcome.
dcheek
Feb 1 2017, 06:25 AM
Try replacing the voltage regulator.
Dave
McLovin
Feb 1 2017, 09:04 AM
QUOTE(dcheek @ Feb 1 2017, 07:25 AM)
Dave
If it's like VW's, some voltage regulators are adjustable. I just did that operation on a beetle.
76-914
Feb 1 2017, 09:43 AM
If it's mounted in the console that is totally normal. Check the voltage w/ a VOM directly on the battery posts to verify. It should at least throw a charge above 1500rpm.
malcolm2
Feb 1 2017, 09:45 AM
alternator belt tension?
southernmost914
Feb 1 2017, 11:05 AM
Your voltage gauge in you center console is fed through the brake circuit and voltage will show a drop when ever brakes are applied. Not a great design and you can change the voltmeters source. At least it lets you know the brake lights are working.
Mikey914
Feb 1 2017, 11:16 AM
Always check your ground strap. It's the easiest solution and hopefully it's it.
