funk
Feb 1 2017, 07:25 PM
At first I thought oh everyone has these but then online once you goto the cheakout box it says item unavailable, unless you want to buy top shelf prices at pelican? any way does anyone know where to get rebuilds? Best price for rear calipers or front and rear?oh yeah for a 1976? but really some people may want to know early?Thanks
Matty900
Feb 1 2017, 07:37 PM
QUOTE(funk @ Feb 1 2017, 05:25 PM)
Try Eric at PMB
http://www.pmbperformance.com/914-brakes/Late_914_Rear.html
ConeDodger
Feb 1 2017, 07:48 PM
How important is stopping to you?
Feb 1 2017, 07:58 PM
Eric at pmb. Because it's alway cheaper to get it done right the first time.
EdwardBlume
Feb 1 2017, 07:59 PM
ThunderbirdDrive
Feb 1 2017, 08:42 PM
PMB all the way.
Just had my set of rears arrive over Christmas.
Great quality.
Now I need to wait for the snow to melt up in Canada and hibernation time to end.
horizontally-opposed
Feb 1 2017, 08:48 PM
Cheapest + brakes
Sounds to these ears like discount + sushi
Ah, and "quality" isn't qualitative. I am sure you meant "high-quality," no? If so, PMB is a great place to start!
funk
Feb 1 2017, 10:34 PM
thanks for the reply's yup stoppings nice!! I suppose its coming down to putting the money where it will count and saving things like new seals for later !!
Mikey914
Feb 2 2017, 01:14 AM
Spend the money with Eric you will not be disappointed.
I'll be around later when you need seals
cary
Feb 2 2017, 08:23 AM
If you want to be frugal. Order the parts from PMB and rebuild them yourself.
They have a couple nice DIY videos on the web site.
Rears are fairly complex with the ebrake and air gap adjuster.
Factory fronts $380 each. Factory rears $1550 each.
NAPA, RockAuto and ECS Tuning have some off brand fronts at $50+, plus core charge.
Good Luck .................
Mark Henry
Feb 2 2017, 08:36 AM
Wood stick, bolt and some hockey tape for the handle, done.
Or you could do it right.
dcecc1968
Feb 2 2017, 08:41 AM
Perhaps OP meant "...cheapest, quality brakes..."?
The power of the comma
RichPugh
Feb 2 2017, 08:54 AM
QUOTE(dcecc1968 @ Feb 2 2017, 09:41 AM)
I was thinking the exact same thing! I read "cheapest quality", not cheapest, quality"... haha
Andyrew
Feb 2 2017, 09:28 AM
Cheapest?
Buy the rebuild kits from Eric and rebuild them yourself. Takes about 2-3hrs a caliper to rebuild them.
Tom_T
Feb 2 2017, 11:17 AM
I think you got the message about Eric Shea's PMB restored calipers, which is what you want to get & be able to really stop, & not be replacing a cheaper rebuilt set later, which will cost more than doing it right at PMB the first time.
http://www.pmbperformance.com/catalog.htmlThat said, I want to add a word of wrning about a specific low quality rebuilder of brake parts for VW & Porsche of which you should beware. I'll warn you that you'll see some lower cost rebuilds by Cardone sold by many suppliers, & they're poorly done & have had many problems. I bought a set from the old Automotion group which were so bad & rusting in the boxes, that I sent them back immediately. Total crap!!
So don't be tempted by
Cheers
Tom
stugray
Feb 2 2017, 12:32 PM
I have a set of recently rebuilt rear calipers with all parts and almost brand new porterfield pads.
Not certain of Early versus Late (didnt even now there was a difference), but they came off of a 71 car.
Mikey914
Feb 2 2017, 12:45 PM
Sorry misread, you said cheapest quality, I don't think URO has made any yet, but until they do here you go, might be a push though
Wonder if they need an updated Periodic table to reflect the new element they are using craponuim
Mark Henry
Feb 2 2017, 02:15 PM
QUOTE(Mikey914 @ Feb 2 2017, 01:45 PM)
What???
No hockey tape on the handle! Are you nuts man????
My solution was a simpler design
krazykonrad
Feb 2 2017, 03:15 PM
Rear brake calipers are expensive because of the parking brake set-up. If I'm right (which I rarely am) the only car to share the 914's OEM rear brakes is some model Ferrari. So the Ferrari guys buy them all up.
That second sentence may be totally unsubstantiated BS, but I heard it somewhere, so I'll repeat it here.
Dave_Darling
Feb 2 2017, 05:54 PM
I believe the Ferrari in question is the 308. The Ferrari version has larger pistons than the 914 caliper has, but is just about the same otherwise.
--DD
Feb 2 2017, 06:09 PM
QUOTE(Dave_Darling @ Feb 2 2017, 06:54 PM)
--DD
308 and 914-6 are the same casting and piston. Expensive from either marque. 914-4 is completely different.
funk
Feb 2 2017, 09:25 PM
Whoa now we are talkin serious auto history. For all AA haters just ignore this but I see centric sells rear for 100$ cheaper than PMB just so all you cheapos know!! but they don't look nearly as nice as pmbs!! I wonder if they are functionally as equal to pmbs?
914forme
Feb 2 2017, 09:57 PM
--DD
Except the bleeder screws end up on the bottom of the calipers. You have to re-machine them and add bleeders in the top. Or take them off and stick something between the pads to bleed them properly.
Oh and Eric, does that service also.
