I recently purchased an original exhaust for my '74 2.0L that's in excellent condition. I was thinking of using the VHT SP104 high heat flat grey paint to finish it off....any advise on other paints that I should consider?
I'm also going to repaint the heater control flaps, boxes and pipes in satin black.....do those need high heat paint as well?
914Next
Feb 4 2017, 02:01 PM
QUOTE(Cal @ Feb 4 2017, 02:47 PM)
Very nice. I wouldn't paint it if I were you.
Tom_T
Feb 4 2017, 02:22 PM
Congratz on the find Jeff! Is it the Leistritz or Bischoff?
Try emailing to Bev & Tom Gould at TC's Garage & ask them to check if they've been able to find the "Porsche Exhaust Gray" which Wurth used to sell, since they're Wurth dealers, Tom is an ex-914er, & they're both some of our most experienced Concours judges in Zone 8.
email Tom at tom@tcsgarage.com or call 760-891-8151
Their website is having some tech problems right now at: tcsgarage.com ....
.... but their Facebook page is working at:
https://www.facebook.com/TCsGarage/?ref=page_internalIf they can't find the Wurth, then ask them what they used on BeeVee's 911 exhaust. You can say that I referred you for their expertise.
Stoddard's used to sell it too.
Otherwise, you may need to do a color match, cuz that Hi-Temp paint isn't really close to the gray Porsche has used on their 149-90's +/- exhaust systems.
Tom
Tom_T
Feb 4 2017, 02:57 PM
Jeff, see the PM I just sent you on this.
Stoddards/NLA, Sierra Madre Collection (see banner ad on here), & other Porsche parts suppliers who carry Wurth may also be sources.
http://www.stoddard.com/http://www.nlaparts.com/store/ > (Stoddard's 356 e-Store that used to carry Wurth' Porsche Exhaust Gray paint)
Tom
914Sixer
Feb 4 2017, 03:32 PM
I ordered exhaust paint from Stoddard in November 2016. Still waiting. I guess I will try calling Monday.
Tom_T
Feb 9 2017, 06:44 PM
Jeff,
FYI - per my PM, here's a close-up pic of where the Bischoff name is on my older but low mile OEM 2.0 Banana muffler from 1980-ish - between the rivets on the inside facing forward when installed, & between the L & R exhaust inlets. I'd assume that the Bishoff, Leistritz or other mfgr name on your new/NOS one is in a similar location, or they may just use a simple logo by the 2010-11 date on yours.
Click to view attachmentBTW - the 04 7 on there is not the date for mine, since I put it on the car in 1980-ish & still have a lifetime warranty from Midas on it!
Tom
dcheek
Feb 10 2017, 08:00 AM
I've used the VHT SP-104 for years. It doesn't last very long, especially after driving in the rain a couple of times. It will eventually show some rust.
They only thing that will last is to have it ceramic coated. Expensive but will last a very long time.
Dave
Mark Henry
Feb 10 2017, 10:14 AM
I've had the best luck with black BBQ/wood stove paint, but it doesn't stand to any road debris for much more than a couple years. Also some cheap ceramics (china T1 stuff for one example) also don't stand up to the real world for very long.
You gets what you pays for.
914Sixer
Feb 11 2017, 07:15 AM
Talked to Stoddard yesterday, they no longer have exhaust paint in the spray can. It is now only by the quart for $60. Not going to work for the average person.
Cal
Feb 11 2017, 08:44 AM
QUOTE(914Sixer @ Feb 11 2017, 08:15 AM)
Sierra Madra carries the Stoddard grey exhaust paint in a spray can. Has anyone used this before?
http://www.sierramadrecollection.com/High-...rey-p28203.html
Krieger
Feb 11 2017, 08:50 AM
I used 3m Weld Through on my stock 911 muffler. I tried it because it is what I had and was tired of spending $ and making parts runs. It has held up extremely well with track use over 18 months. Three years total time. No used in wet conditions though. I would buy a can to do this again. I wire wheeled and cleaned before I sprayed.
Tom_T
Feb 11 2017, 12:06 PM
QUOTE(Cal @ Feb 11 2017, 06:44 AM)
http://www.sierramadrecollection.com/High-...rey-p28203.htmlJeff,
Double check back with Stoddard to verify that this at SMC is the same paint as their quarts, & that they're both the same color as the former Wurth Exhaust Grey Paint.
If it is, then it will be a good match to the 1950's - 70's Porsche exhaust grey color, but may show up a bit lighter than the paint currently on your muffler. I'm not sure it it was a tad darker grey originally, or if it's darkened with age & oxidation.
I've judged several 356s & 911/912s with their exhausts done in the Wurth/Stoddard Porsche Exhaust Grey, & they look really good.
I'd suggest that you can paint both your muffler, & your SS HEs that you had an earlier topic about (if you're still planning to do so), at the same time with this exhaust paint, so that everything is in the same grey & same age for oxidation/color fade/change over time. So try to buy all of your paint at the same time from the same case(s)/batch, so that they're all in the same color mix batch - rather getting some now & more later. Also get a can or two extra at the same time/batch in case you need to do any future touch-ups.
Thanx for doig the research on the current supplier on this.
Tom
Tom_T
Feb 11 2017, 12:12 PM
QUOTE(Krieger @ Feb 11 2017, 06:50 AM)
Wurth also makes a high-zinc (98% IIRC) weld-through primer which dries to a similar grey to the Porsche Exhaust Grey color - which I've used to prime areas on my 914 after wire-wheeling off surface rust as a rust preventative holding measure as I slowly work on my 914.
But I don't know if theirs, 3M's nor Eastwood's zind-rich weld-through primers are high temp for use on exhaust systems.
If so, then I would still use them as the primer coat to prevent more rust, then top coat with something like the Stoddard Porsche Exhaust Grey Hi-temp paint as the top coat, since the primer is more porous, while the paint will seal out the moisture better.
Tom
Update.....I ended up using the VHT SP100 primer and the VHT SP104 flat grey finish paint. It turned out very close to the factory grey color and very easy to work with. I just need to cure it per the manufacture specs.
Tom_T
Apr 3 2017, 08:25 PM
That looks real nice Jeff!
Tom
Jett
Apr 3 2017, 08:28 PM
Great job, looks clean.
...also motivating me to do the same
Lucky9146
May 4 2017, 03:21 PM
I don't know if you considered it but I ceramic coated mine silver for the 6 conversion and it came out like this. I love it. Not original looking but pretty cool. There may be a ceramic grey. Cost was $150 here just north of San Diego.
Tom_T
May 4 2017, 03:52 PM
For those looking for a PC or Ceramic option close to OEM gray -
There are both a Ceramic & a Hi-Temp PC Gray which is very close to the original Porsche "Exhaust Gray" paint shade, but you have to really go thru the color chips books to find the right one, & then compare it with the actual paint on an NOS exhaust part or the OEM paint in the sunlight for a proper match.
While it looks like a beautiful PC job on your -6 Banana - that's way too much "butt-bling" on a 914 for me!
.... ergo I'm considering painting or Ceramic or HT PC coating gray on my SSI SS HEs, to match the Leistritz Sport Banana 2L muffler for my 73 2L.
Tom
horizontally-opposed
May 4 2017, 04:55 PM
You might try West Coast Powder at 925 682-4828. I spoke with Kelly.
They have a light gray and a white that interested me, but while the light gray is close it has some sheen to it. If you want true factory looks that will last, I was told one way to get there is to ceramic coat it, then etch the coating, then apply another coat (primer) in a ceramic setup, and then finally hit it with light gray VHT.
I have tried the VHT route and it peeled quickly. It's a non-starter for me.
Jet Hot Coatings offers a nice light gray as well. It has a very small amount of sheen to it, as well, but I may go that way.
Let us know how it goes if you beat me to it, will you?
pete
mb911
May 5 2017, 05:25 AM
Look up cerakote. Its a ceramic paint and is high temp. Either oven bake or air cure. I use air cure for my 911 fan and fan housings restorations.
Jett
May 5 2017, 08:31 AM
I used stoddard grey on my 1.7 muffler and ceramic coated the NOS heat exchanges and NOS muffler for our 73 2.0. Will post pics tonight.
Matty900
May 6 2017, 12:48 AM
QUOTE(Jett @ May 5 2017, 07:31 AM)
I just dropped my heat exchangers and muffler off today for ceramic coating. I went with the black on the Heat Exchangers because it is supposed to reduce as much a 60% of the heat radiating from them in to the engine bay. The other colors insulated less but I don't remember how much less. I want to say it was like 45%.
Tom_T
May 6 2017, 12:28 PM
QUOTE(Matty900 @ May 5 2017, 11:48 PM)
I just dropped my heat exchangers and muffler off today for ceramic coating. I went with the black on the Heat Exchangers because it is supposed to reduce as much a 60% of the heat radiating from them in to the engine bay..
I'm not sure that it's a good idea to hold that heat in them Matty, especially being an air cooled engine.
Even for cold climates, once the heat radiates/transfers to the outer skin of the HEs, it's pretty much spent in transferring heat to the air chamber for cabin heating.
After all, Porsche chose their exhaust paint colors for a reason, & based on their vast racing experience.
So you may want to rethink your color choice & stick with something closer to stock.
JMHO!
Tom
moorepower
May 7 2017, 09:30 AM
I would use Tech Line Coatings Black Satin. Coat the outside of the heat exchangers and the outside of the muffler. It will reduce the amount of radiated heat from the exhaust system heating up the air surrounding the engine, allowing the cooling fins to to a better job. It also makes the heat exchangers more efficient for the purpose of heating the cabin. Before I sold the business, I coated headers, exhaust systems, and a multitude of various engine parts, ect for 19 years. The coating is very effective on heat exchangers, for colder climates.
DennisV
Mar 2 2024, 11:57 AM
Has anyone sprayed the
Wurth High Heat Aluminum Paint?
I am wondering if it is even close to exhaust gray, or rather a bright metallic finish as "aluminum" might suggest.
As of 2024, many of the paints mentioned in this and other threads are NLA.
For our 914-6, I'm planning to buy a pair of new 914 heat control flapper boxes. Cut a hole in the cap and paint them gray to be closer to 914-6 original.
Thanks.
Mar 2 2024, 12:41 PM
The oem 914-6 flapper boxes that I’ve seen were a medium to dark grey. I’m guessing they started out light to medium grey but some got darker from age/exposure. It’s a matt primer grey, not glossy or metallic. I’ve changed a couple 4’s to 6’s with a 7/8” metal hole saw and a drill press. Then I blast and powder coat black - I wasn’t going for originality on the color. I don’t think the flappers get particularly hot. It’s not like exhaust temperature heat is entering the cabin area.
Ishley
Mar 2 2024, 08:39 PM
I’m a fan of cerekote. Withstands the heat and looks good. Everything I’ve used is the air dry version and it drys a matte finish. The trick with Cerekote is you need a really clean blasted metal surface. You spray it with a HVLP gun. A single cover coat is all you do. Thick coats will bubble and you have to start over.
nivekdodge
Mar 2 2024, 10:03 PM
I just did Cerakote's
air dry on my exhaust and it seems to be working
Kevin
rick 918-S
Mar 3 2024, 07:16 AM
I have some galvanizing spray paint I picked up at the local welding supply store. Radnor Brand. It is a nice gray color and holds up well.
mb911
Mar 3 2024, 04:21 PM
Big fan of cerakote but I can tell you my favorite paint for exhaust that matches OEM is rustoleum 2000 degree primer.
porschetub
Mar 4 2024, 10:40 PM
Using the same VHT product ,well pleased with it and no burn or corrosion on the hot spots, used this paint on a preheated clean muffler but IMO prep is key to getting it to last .
Cleaned all the old coating off and wire buffed till the whole thing was shiny then used emery tape to help key the paint on the surface,warm day but nuked it with my heatgun,did this on every coat ..looks great and lasting well cheers.
barefoot
Mar 5 2024, 12:07 PM
I did my 911 parts with Jet cote some yrs ago looked very good:
Click to view attachment Click to view attachment
