If you translate the Chassis No. Dave mentions above, then you can get the actual date (-ish) when yours was built, by using a 1975 calendar to count weeks, using the chart below.
Click to view attachmentNote that the 95 was the Karmann plant denoter, & the 5 would change to 6 or 7 for 100 or 200 + XX number of cars pr day, & contrary to the info on the chart, the 6/7 were used in 74 MYs too, when they were building 20-30K 914s a year.
At 274 from the end, you're probably a week or so from the end of the 75 MY cars, I'd guess. Total production numbers by calendar year are at the link below, but that would mix 2 MYs into each calendar year's numbers.
http://www.914world.com/specs/productionnumbers.phpMy early 73 has the dubious notoriety of being the fastest 1-day build 914 on 8/31/72 - but they weren't
really accurate as to the day nor time of build.
Tom
