Gearren
May 2 2005, 05:52 PM
I am ordering bushings for my suspension and I don't know what size front sway bar busings to order? I have a 73 2.0.
TravisNeff
May 2 2005, 05:55 PM
Tell us about the rest of your suspension setup. What do you want to do with the car? Do you have a swaybar now?
Mueller
May 2 2005, 06:07 PM
QUOTE (Gearren @ May 2 2005, 04:52 PM) |
I am ordering bushings for my suspension and I don't know what size front sway bar busings to order? I have a 73 2.0. |
the swaybar size should be stamped on the end of the bar if factory, or just measure the OD of it......use an open end wrench on the round portion of the bar...not too hard and you have a few choices on what will fit..........
Gearren
May 2 2005, 06:08 PM
It is the stock sway bar, and I don't know what size came stock?
smg914
May 2 2005, 06:11 PM
The stock factory front sway bar on a '73 914 was 15mm.
The stock factory rear sway bar was 16mm.
Mueller
May 2 2005, 06:12 PM
QUOTE (Gearren @ May 2 2005, 05:08 PM) |
It is the stock sway bar, and I don't know what size came stock? |
16mm I believe
Gearren
May 2 2005, 06:13 PM
Thanks, I just measured, and the front is 15mm.
