Harpo
Feb 18 2017, 09:46 PM
I removed the unneeded 911 brackets and welded the 914 adapter on to the outer tube. The bearings and the actual steering shaft are not included. You will need to provide them
All of the cutting grinding & welding is complete also I have painted since this photo was taken
100 shipped in CUSA
bdstone914
Feb 19 2017, 07:01 AM
All you forgot was the price.
Harpo
Feb 19 2017, 10:14 AM
The price is $100 including shipping.
The 914 steering shaft and lower bearing can be used and I will include with this 914-6 clone column. The lock function will not work and the upper bearing will not be included but McMark has a very nice option.
McMark
Feb 20 2017, 07:32 AM
You want that upper bearing back to go with this? Still sitting where we left it.
Also, this won't fit 70-71 cars.
Harpo
Feb 20 2017, 04:28 PM
Thanks Mark, your right of course the older 914 had a different bracket. Your aftermarket top bearing is far superior.
David
Mikey914
Feb 21 2017, 02:48 AM
I'll take it. Looks like the clam shells may fit this one. It will also allow me to check some measurements.
-Mark
jkb944t
Feb 21 2017, 06:50 AM
I'll take it if Mark changes his mind.
Jeff B
Harpo
Feb 22 2017, 04:50 PM
Larmo63 sent me a PM on 2/20 claiming to want it. If he passes then Mark is 2nd then jkb944T is 3rd.
Thanks
David
