TravisNeff
May 2 2005, 11:23 PM
I drained out my gas tank last night and removed it today getting ready to weld in the Engman reinforcments for my swaybar. Today I removed the tank and cleaned up a little - lots of mouse turds and crud. Pulled my swaybar and the outer bracket - there was no inner bracket. I had to cut away the front wheelwell reinforcement piece, a dremel with a cutoff wheel did a pretty good job here.
Below are pictures of my mount in place, I drilled a couple of holes between the mounting bolts that I will rosette weld from the outside, then seam weld the piece around the perimeter of the mount on the inside. I found a crack on the lower bolt hole which goes fore/aft and another crak going up and down just to the left of the lower mounting bolt. I will weld up those cracks when I remove the bolts from spot welding the outside and burn into the backing plate.
TravisNeff
May 2 2005, 11:24 PM
Another shot of the tear
TravisNeff
May 2 2005, 11:25 PM
A picture helps, eh?
TravisNeff
May 2 2005, 11:27 PM
Notice on the last pics, someone down the line drilled an extra hole so they could hold a loctited nut while they tightened up from the front - hokey. It will be hard to weld that up, so I may just leave it - what do you think?
TravisNeff
front trunk
TravisNeff
May 2 2005, 11:28 PM
gas tank bay
TravisNeff
May 2 2005, 11:29 PM
nuther'
TravisNeff
May 2 2005, 11:30 PM
That's all for now, I'll show you how it turns out. Daisy, my new Boxer puppy and I thank you for stopping by
bryanc
May 3 2005, 03:27 AM
Hi Travis
Does the Engman plate not have an outer bracket like the factory and Weltmeister bars do?
JoeSharp
May 3 2005, 03:39 AM
I'll be watching Travis, I want Tarret bars for Carerror.
I wish I knew before the party.
Joe
TravisNeff
May 3 2005, 08:22 AM
Bryan, the engman piece is just the inner backing plate with integrated nuts on them. I have the welt outer plate which holds on the bushing - just not on the car for the moment for fitup and welding. Without the inner plate along with the outer plate sandwiched over wheelwell the tub can crack from stress.
Joe, those tarret pieces ought to be the bomb. I have their droplinks on my welt bar and like them a lot!
Jeroen
May 3 2005, 08:32 AM
QUOTE (Travis Neff @ May 3 2005, 06:27 AM) |
Notice on the last pics, someone down the line drilled an extra hole so they could hold a loctited nut while they tightened up from the front - hokey. It will be hard to weld that up, so I may just leave it - what do you think? |
fix it now!
that area is stressed when the swaybar is loaded
ya don't want it to tear or crack...
TravisNeff
May 3 2005, 08:38 AM
QUOTE (Jeroen @ May 3 2005, 06:32 AM) |
fix it now! that area is stressed when the swaybar is loaded ya don't want it to tear or crack... |
Yeah, figured I'd have to do that. I can see that the crack goes straight to that hole, bah.
TravisNeff
May 3 2005, 11:47 PM
Good bad and the ugly, here we go. I welded up some patches where the access holes were, passenger side went good, driver side a little boogery but it's in there. On the reinforcment plates I welded the perimeter as best I could (not much room to maneuver around) and ran a few spots from the outside through the wheelwell into the mount for added strength. Tomorrow I will patch back up the squares I cut out for the reinforcents.
TravisNeff
May 3 2005, 11:49 PM
I also welded up the cracks in the wheelwell right into the plate (see above pic).
TravisNeff
May 3 2005, 11:50 PM
asdf
TravisNeff
May 3 2005, 11:51 PM
Looks like I got good penetration..
TravisNeff
May 3 2005, 11:52 PM
I need to grind down the outer welds and POR15 them up, I'll do it in silver to hide the burn marks and maybe it won't look so fuglee
TravisNeff
May 3 2005, 11:53 PM
last one, I think this one is blurry
Trekkor
May 4 2005, 12:19 AM
Travis, are you using a flux coated wire feed or MIG?
That looks very strong. You shouldn't have any probems with the body tearing anymore.
What's next?
KT
JoeSharp
May 4 2005, 03:20 AM
Mine will look much prettier than that. I like large burned holes and big gobby fill in.
Joe
TravisNeff
May 4 2005, 10:08 AM
I am using solid wire with Ar/CO2 I didn't clean up the welds before taking the pictures. I will do that tonight after I ground down the welds in the wheel wells tonight.
What's next? Engman stiffening kit of course
TravisNeff
May 4 2005, 10:55 AM
Whoops, just for clarification those swaybar brackets are Tarret pieces, not Engman. I have the Engman inner long kit - that is the next project
