QUOTE(71gold @ Feb 21 2017, 06:21 AM)
So here is the situation.
With ignition to on, can hear the realy for the 1.5 seconds
I removed my fuel pump and hooked to power and it works.
Also checked the wires to pump and there is power for the 1.5 seconds.
This car ran just fine last fall and when started this year was fine till I got down the road a mile from the house and went dead. I was low on gas and maybe out of gas so refilled and no start , so went thru the above tests.
Maybe I'm not understanding what you're saying, but from you wrote, it sounds like the ECU, at least the fuel pump control circuit, is working properly. What is not working that makes you believe the ECU is at fault?
BTW, in general, it's very easy to test the basic function of the ECU. First, test the fuel pump, by turning the key to "on" and listening to hear if it runs for 1.5 sec. Next, without starting the car and the key in the "on" position, slowly depress the throttle to the floor. You should hear 20 clicks from the injectors, which tells you that the injector driver circuit of the ECU (one of the rare circuits in the ECU that fails) is working. Now, crank the car with a voltmeter across the fuel pump, if you see +12V, the overall fuel pump circuit is working. If the car starts and the fuel pump continues to see +12V, you've now shown the prime, crank, and run functions of the fuel pump circuit are working.
If the car starts, use a Noid light (like $10 or less from Amazon) on each of the injectors. If they all flash, then you've just tested all of the timing loop circuits, the pulse width multiplier, and a host of other circuits. It's likely your ECU is OK.
You can also test the TS1 and TS2 (temperature sensors) circuits by disconnecting them while the engine is running. Disconnecting TS1 (air) should change the running slightly, disconnecting TS2 (head) should cause the engine to stall rich. If the engine runs and all cylinders show firing with the Noid light, then the trigger contact points circuit is working correctly.
To test it further, you'd need to do more specialized tests, like measuring the injector pulse width as a function of load and engine speed, which would require equipment most people don't have.
