QUOTE(Tom_T @ Feb 22 2017, 01:53 PM)
QUOTE(BillC @ Feb 22 2017, 06:57 AM)
Take a look here:
http://www.914world.com/bbs2/index.php?act=colors Alaska Blue is the second line of the table.
L96B is the VW color code. 78 is the Porsche color code for the same color. So, your COA is correct.
No .... the COA is incorrect, as they switched to only using the VW paint code by 73 MY, & PCNA should be doing their COAs to match what is on the Karmann Plate of the car. Confirm what number is in the bottom box of the Karman Plate in the front L door jamb (driver side), & take it up with PCNA-COAs per belwo.
Turbonnet, see if you can verify that your 914 was originally sold in Canada - if so, then the COA would be correct as noted above by Mark H. - but if NOT & was actually first sold in the USA, then the PCNA COA person also made a mistake in translating the option code on the Kardex record as Canada Eqpt.
After you know that question, call the PCNA 800# for the COA dept. & ask them to correct one or both items, & anything else you think sounds wrong on it (if any).
PCNA is notorious for screwing up the COAs on all the older cars (including 356s, 911s, 912s), & apparently especially or more often on what they consider our NARPy-bastard 914s - but they have an obligation to correct the COAs for which you/we pay good money.
It took me 4 tries & many calls & emails to get them to correct mine, but they eventually got it right. Others get it right the 1st or 2nd time. If you run into trouble, just shoot me an email or PM & I'll tell you what to do to take it up the ladder at PCNA.
Good Luck!
Tom
I went through this with Porsche in 2015, when I got the COA for my '73 1.7.
When I received the first version of the COA, it said my car was paint code 26G, Conda Green. It's actually Saturn Yellow (paint code 26/L13M). After being told several times by a rather snobby Porsche COA person that their records are correct and that my car must have been repainted (completely, all over, even under the dash, under the rear trunk, etc.), I finally got them to look at the 914World paint code page to which I referred earlier. At that point, they were willing to concede that they made a mistake and fixed the COA to say paint code 26, Saturn Yellow. This is despite sending them multiple pictures of the car and of the paint placard in the door jamb.
The point of this story is that the person at Porsche insisted that Porsche only recorded the
Porsche paint code and
absolutely did not record the VW paint code. So, she didn't care that the picture of the paint placard clearly showed L13M -- she said she had no idea what that "L13M" represented and could only go off her data sheets.
Of course, I have absolutely no way to verify what she told me about what was or wasn't recorded, I can only relay what I was told. But, since my COA now has the correct paint name, I figured it was acceptable and didn't pursue it any further.
