QUOTE(Philip W. @ Feb 23 2017, 02:41 PM)
ok read back thru the other thread and this confirms what I thought-
fyi forgot to say this is a newly rebuilt MPS and it was so lean on first start car would not start, took 2 full rotations just for car to start( turns out to make more rich- it was that lean !)
so after driving a week this is where I was at, but I also discovered that the CHT was not the correct one- but I had one in my box that is a #12 ive had stashed away for some time, since back when you could by them from Autohauz for $30! and I just put this one in , and I will adjust the MPS to bring that WOT and cruising A/F reading closer to the 13.5 range and see how its doing(yes timing is set fyi,)
Ok so now after slight adjustment and drive home- a1/4 turn out and the a/f @3200rpm was 13.2-13.5 , 12.5 or so on wot.
