QUOTE (montoya 73 2.0 @ May 3 2005, 04:02 PM) |
check the fuel tank for rust? how do i do that? |
QUOTE (montoya 73 2.0 @ May 3 2005, 04:21 PM) |
Okay! will do the fuel tank and brakes. cool! what kind of dual carbs are best for a 2.0? |
QUOTE (tat2dphreak @ May 3 2005, 01:25 PM) | ||
weber 40s are fine for a 2.0, you may want to up the jet sizes though... I did for my 2056, anyway... if it's a STOCK 2.0 though, you MAY want to try and find an FI from someone who converted to carbs... up to you, though... |
QUOTE (montoya 73 2.0 @ May 3 2005, 04:37 PM) | ||||
not familiar with FI. how difficult are they? |
QUOTE (Joe Sharp @ May 3 2005, 03:27 PM) |
Your going to be on a tough learning curve. Just get it home first. If it were me I'd stand on the brakes a few times just to make sure they don't go to the floor where its at. Change the fule and any fule lines I could see that showed singes that they are dryed out, change them all or be on fire alert. Once you jet it running and take it around the block as soon as you can try to lock up the brakes, if you can't brake a hose or seal by standing on the peadel just go home. I'm a carb guy, I have been working on a D-Jet car for about 18 months. Complet rebuild of the motor and D-Jet system. It is a 2065, 9.5:1 CR, balenced, ported and camed. I'm in the final stages of tuning it and am quite happy. But I'm not in a hurry, and its my hobby car, not something I need to drive. So you can't compare that to a stock D-Jet in a driver. But you still need tools and knowlege. It's up to you. only you can desideand thats what this is all about. Check my blog. Joe |
QUOTE (tat2dphreak @ May 3 2005, 02:49 PM) | ||||||
others can chime in here... but they can be learned... dual carbs aren't as easy as it sounds... it requires proper balancing and jetting, not a snap... i do not know FI |
QUOTE (montoya 73 2.0 @ May 3 2005, 02:21 PM) |
QUOTE (john grier @ May 3 2005, 03:58 PM) |
Hey there; If it was me, I would prefer the stock fi. I have had both carbs and fi, but I like the fi best. Just my opinion but the fi seems to run smoother. |
QUOTE (anthony @ May 3 2005, 04:08 PM) | ||
Have you priced a set of carbs lately? The 44mm Webers are NLA, 40mm Webers are $1K now, and prices on used carbs have shot up proportionally. |
QUOTE (mudfoot76 @ May 5 2005, 03:17 PM) |
Tuning and jetting to me is Black Magic but I want to learn more... |
