tazz9924
Feb 25 2017, 10:18 AM
Hello all! im curious if its generally cheaper to buy somones used set of 5 lug rear hubs or if its cheaper to have mine redrilled and have studs pressed in? also where do u buy lug studs for this?
GeorgeRud
Feb 25 2017, 10:45 AM
Probably not a big deal otherwise, but if your hubs are the early style with five bosses, I'd have them redrilled for the five studs. I had mine done years ago at FAT, but it's a pretty straightforward conversion, but I'm not sure who does them these days (perhaps check with PMB). If some are already done and available, do whatever is cheaper.
Spoke
Feb 25 2017, 11:02 AM
If you redrill your hubs for 5-lug, definitely have them tapped for screw-in studs. Eric at PMB did this for me. Bought the studs at track-studs.com and installed them myself. Screw-in studs also allows you to change stud length for new wheels w/o removing the hub.
Track Studs
Bgyglfr
Feb 25 2017, 11:22 AM
Just curious, if you switch the hubs out, what hubs work best for this conversion?
tazz9924
Feb 25 2017, 12:24 PM
well does anyone have an extra set?
mb911
Feb 25 2017, 05:17 PM
QUOTE(tazz9924 @ Feb 25 2017, 10:24 AM)
I have a friend that can do them for you pretty cheap. He did mine and they turned out great. Mine are. Pressed in though.
Spoke
Feb 25 2017, 07:39 PM
QUOTE(tazz9924 @ Feb 25 2017, 01:24 PM)
Check with Bruce Stone BDStone914. He always seems to have something interesting to sell.
bdstone914
Feb 25 2017, 11:48 PM
[/quote]
I do have a couple of sets in the works. I do the press in studs. $200. outright with studs installed.
Bruce
tazz9924
Feb 26 2017, 12:15 AM
[quote name='bdstone914' date='Feb 25 2017, 09:48 PM' post='2458355']
[/quote]
Bruce
[/quote]
is that without core?
Chris914n6
Feb 26 2017, 03:20 AM
My local machine shop charges $45 for a half hour. Call around to make sure they have an "indexer" as the first 3 didn't and couldn't. Bring a stud to get the right sized hole drilled.
If you have the late hubs then bosses should to be welded in for strength.
